andybk
Apr 01, 2024Aspirant
RBR 750 Firmware Version 7.2.6.21
Neither the Orbi app nor the web interface will display the list of attached devices. This is a security threat as there is no way to check for unauthorized access.
Is this in the web browser or Orbi app?
What browser are you using? Try MS Edge or Firefox?
Be sure to clear out all browser caches befor entering the routers web page.
- andybkAspirant
Yes, have cleared caches. Using Safari and Vivaldi. Note, same problem in the Orbi App. Netgear support says known bug, my post is really meant to jog Netgear to get moving on a firmware update.
After a setup from scratch, try Firefox instead as well as Safari.
NG doesn't watch the forums. Best way to make them aware is thru official NG support ticket.
