cjlutz's avatar
cjlutz
RBR 750 Problem
My Orbi RBR 750 Router is not connecting to my ISP modem. I've tried all of the troubleshooting methods without success. On the Orbi Iphone app I get an "orbi not found" message. I've tried a factory reset and reboot on the router and it has a solid white light. I connected to my ISP modem and the connection to the Orbi router fails the connection test. I see the ORBI93 wifi network on iphone and laptop but clearly an issue connecting that I can't fix.
Any suggestions appreciated!
  • Hello Community,
    I have the exact same issue.
    Installed firmware = NETGEAR Orbi 2.12.6.1824
    Smartphone used = Google Pixel 5
    There's no other ORBI network around.
    I unactivated mobile data on the smartphone to be sure to used ONLY Orbi WiFi LAN connection.
    Connection to web admin interface works just fine.
    Any idea ? Thanks.
    Kind regards,
    • FURRYe38's avatar
      Please make a new post in regards to what your having problems with.
      Thank you.
      Yahey wrote:
      Hello Community,
      Any idea ? Thanks.
      Kind regards,
