chris38's avatar
chris38
RBR 760 satellite
Hi
i have a orbi rbr760 with 2 satellite, i want to add an other satellite but i don't found the same reference.
is there an other version is compatible with RBR760 ?
Thanks
  • plemans's avatar
    How big is your home?
    There's been a few times, we've actually seen people have to many satellites and it causes issues with roaming and stability.
    A router and 2 satellites should cover a fairly large home (provided it isn't made from brick/concrete/plaster lathe)
    • StephenB's avatar
      Agreed.
       chris38​:  Before you purchase, I suggest checking the signal strength around your home using a wifi analyzer on your phone.  If you are seeing RSSI values of -70 dbm or better, then you should have good whole-house coverage.
      If you see an area where you are getting -30 dbm or better from two or more mesh elements, then you likely have some interference.  If that is your situation, you could repositioning the satellites.  Or try one of them off.
      • chris38's avatar
        chris38
        my house is with 3 level, the modem is in the middle, i don't have issue with the wifi inside
        but i have camera outside and  i don't receive the wifi on 1 side of the house outside
        is why i want to put an other satellite for the outside
        did you have a good app for ios for analyse the wifi ?
        Thanks
