Big_Denny's avatar
Big_Denny
RBR 850 satellite intermittently drops internet
Product: Orbi RBR850 w/ 1 Satellite bought packaged together from Best Buy
The satellite intermittently loses internet access or connection to the router once or twice a day. Thew connection functions normally the rest of the day.
the satellite seems to go through a reset of some kind flashing orange and restoring a blue connection after about 5-10 minutes.
Have already performed factory reset and updated to firmware version 3.2.16.6
Verfied that devices connected wi-fi to router maintains stability and internet.
Only devices connected to satellite lose internet but devices still show healthy wifi signal.
Is this a hardware issue?
Any help will be appreciated.
Denny
  • I'm assuming you meant RBS850 Satellite?
    Is the satellite wired or wireless? If wired, chech the network cable.
    I wireless, what is the distance between the satellite and RBR850 router?
    Also check the power supply to make sure it is not faulty.
    And lastly it could be a defective satellite.
    • Big_Denny's avatar
      Big_Denny
      Yep, it is the RBS850 satellite.
      Wireless.
      Just over 30ft. We had it further before and the drops were very frequent. At its current location, it went about a month with no hiccups whatsoever. And it still has strong connection all day until the random 5-10min where it disconnects/restarts, once or twice a day.
      Opened a support ticket today and the rep mentioned this so I will get a new a/c adapter and plug it into the wall versus the surge protected strip it is on right now.
      Have an open hardware ticket. Just sucks that the hardware is new from May, at least the warranty applies.
      • Mstrbig's avatar
        Mstrbig
        Master
        It could be power drops, surges, spikes, brownouts, depending on where you live. It's been terrible, where I'm at in Tampa Bay, with daily brownouts, due to storms and hot weather.
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
    Be sure to post about this over in the Orbi AX forum:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Denny
      Big_Denny
      We actually had it closer to 40ft away when we got the system in May, but the connection would go purple fairly periodically. At its current location at about 32ft, it was functioning properly for the last few months with no drops/disconnects at all.
      From about 4 weeks ago, it would start going orange or purple about 1-2 times daily and take about 5-10 minutes to get itself sorted.
      The router is fine and stays connected to the internet.
      Channel 6 for 2.4Ghz and 48 for 5Ghz
      Most neighbors have wifi, probably all around us in a 100ft on each side and more like 1000ft front and back. When searching for a network, i can spot at least 8-10 strong signals.
