gursoynecdet
Dec 07, 2023Tutor
RBR 850 with 6 satellites backhaul problem
Hi
I ve been using orbi mesh for such a time,
I have RBR 850 as a router
then 6 satellites connected with ether all over the house
The problem is sometimes system shows backhaul on ethernet (good),then sometimes switches to 5G (poor).
I want them to use backhaul on ethernet, (not automatic).
Thanks for the help
The most obvious possibility is that the wire connection between router and satellites has been disrupted.
- Is there perhaps a switch involved in the path between router and satellites?
- Do ALL satellites switch from 'wired' to WiFi at the same time?
- Do they ever switch back?
Netgear says the AX systems support six satellites:
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
All six 'wired' should be the optimal structure.
These cable connections are probably going through a patch panel somewhere in the house?
