andymeakin
Mar 16, 2023Aspirant
RBR350 triggering house alarm
I recently bought a RBR350 mesh system which it turns out is triggering my house alarm. If I turn off the RBR350s, no problem, with them on, it will trigger the alarm immediately up to within a few minutes. I've tried moving the router to a spot further away from any sensors, but it still affects the alarm.
I bought the system as Wi-Fi was poor in some of the rooms. These units seem to have much more range each than my previous router did so perhaps there is a way to turn down the signal strength? Any other suggestions?
Otherwise it seems I can choose between security and good Wi-Fi, but not both 😣
What alarm system is it?
Have you tried changing what wifi channels the router is on? or the security system?
Almost sounds like the sensors for the security system are on the same bandwidth and something's broadcast must trigger it.
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
- andymeakinAspirant
Thanks FURRYe38, I've made the changes to reduce the power output to 50% and will test it out.
My house is around 2000 sq ft and yes, I have the router and satellites about 30 ft apart. Ironically, even with the just the base station router on and both satellites off, the Wi-Fi coverage is significantly better than my previous router, so hopefully reducing the power output works.
Thanks @FURRYe38, I've made the changes to reduce the power output to 50% and will test it out.
What alarm is it?
Did you try changing the wireless channels?
