JustRic's avatar
JustRic
RBR50 as extender to RBRE960 + (2) RBSE960
I upgraded my Orbi system from the AC3000 (RBR50 + RBS50) to the Orbi 960 Series (RBRE960 + (2) RBSE960). Is it possible to use the older Orbi router and/or satellite to extend the new AX11000 system and would there be any benefit in doing that?
Thanks,
Ric
    • CrimpOn's avatar
      CrimpOn
      FURRYe38 is entirely correct that the original Orbi "50" router and satellite are not compatible with any of the AX product line.  If there is part of your property that is totally outside the coverage area (such as a barn, boat dock, etc.) then the old system could be redeployed to that location to create a separate WiFi network at that location.  The major obstacle to that use is that the Orbi router WAN port must be connected with Ethernet, either a physical cable or a wireless bridge that appears to the router as Ethernet.  Users who need remote coverage most likely have already addressed the issue, so my guess is that you're stuck.
      Now that WiFi has become essential to our daily lives, it might be worth taking a minute to consider "what's the plan?" if the new WiFi router fails.  If you can drive to Best Buy and have a replacement running in a couple of hours, that's a plan.  Otherwise, it might be worth keeping the old Orbi setup in a box "just in case."
      • JustRic's avatar
        JustRic
        Thank you CrimpOn! I appreciate the additional information and suggestions. Cheers!
        Ric
    • JustRic's avatar
      JustRic
      Thank you FURRYe38 for that information! The new system does indeed provide faster WiFi and better coverage than my old AC system. I suspect I will not miss the old system much at all. Since the old system still works I thought I would use it along side the new system, if compatible. Since it is not I will see if I can find someone who has something older that might want that system as an upgrade. Cheers!
      Ric
      • FURRYe38's avatar
        You should be good with the 960 alone. I'm enjoying mine currently. Ya I do have the 50 series as well. It's in it's box and used for reference testing when needed. You could keep it as a Just In Case kind of thing. Or find it a new good home that needs good wifi.
        Good Luck.
