RJG202
Sep 19, 2025Guide
RBR750 and Citrix Connection Interruptions (New)
I have a RBR750 and satellite with Firmware V7.2.7.15 and running Citrix Workspace App for Windows Version 25.03.10. I am using a Dell Inspirion I7 with Windows 11. This has been running fine for m...
- Sep 20, 2025
Spent over an hour with Dell support. We rolled back the WiFi/bluetooth driver that was auto installed. Seems to be an incompatibility as the previous WiFi driver works. The laptop is 8 months old and there was a dell service that automatically installed updates I did not know of. That is not disabled.
thanks
Sep 20, 2025Guru - Experienced User
If win10 PC is working at same connections and places and windows 11 isn't and has been running fine up to this point, you'll need to take review of the windows 11 PC, VPN connections and Citrix support help and information regarding this.
Make contact with the PC, VPN and Citrix mfrs for help and support.
Update the PCs ethernet or wifi adapter drivers.
Try ethernet connection vs wifi on the windows 11 PC.
Try non VPN connections to help rule out VPN issues.
