Barre_A's avatar
Barre_A
RBR750 and RBS750, keeps disconnecting. Some devices is still connected, need reboot.
I have Orbi mesh RBR750 with RBS750, distance between these is 8 meter.
My devices are disconnected from my router. I live in an apartment of 80 sqm.
Sometimes I have 5 devices connected and sometimes I have 15, I sometimes have to restart my router 3-4 times before all devices are connected. Today I have restarted 7 times and still not all devices are connected, I have internet.
I have had this problem for a couple of months months, this is not okay.
I don't have any defualt name on my wifi, i have neighbors but this does not affect when i tested other router.
What can i do to fix this ? If it can't be fixed then i want to change router to something better that netgear have.
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
    • Barre_A's avatar
      Barre_A
      Firmwire : V4.6.3.7_2.0.49
      i don't know MFR model#
      i have now tried to set different chanels for 2,4Ghz and same for 5Ghz.
      I have a couple of neighbors, but if Orbi can't handle some neighbours then that router is not for me. I have tried other routers and they can handle that.
      I did turn of those things.
      Seems that these steps is allway asked to be done no matter the issue, but this did not help me.  any other things i can do or can i return my product ?
      • FURRYe38's avatar
        Ask the place of purchase about return policies.
