rohanzanje
Apr 18, 2026Aspirant
RBR750 Boot Loop - White Light Flashes Then Goes Dark, TFTP Recovery Failing
RBR750 Boot Loop - White Light Flashes Then Goes Dark, TFTP Recovery Failing Device: Orbi RBR750 (Serial: 6661037RA0169, Firmware was V7.x, Purchased April 2020) Problem: Router powers on, wh...
- Apr 26, 2026
This issue was resolved with factory reset which for some reason wasn't going through in my initial few attempts. Also with firmware update my routers pass through speed has increased 7-8x than earlier. Thank you.
Apr 18, 2026Guru - Experienced User
Try a 30-30-30 reset on the RBR. IF this fails, unit maybe bad.
