rohanzanje
Apr 18, 2026Aspirant
RBR750 Boot Loop - White Light Flashes Then Goes Dark, TFTP Recovery Failing
RBR750 Boot Loop - White Light Flashes Then Goes Dark, TFTP Recovery Failing Device: Orbi RBR750 (Serial: 6661037RA0169, Firmware was V7.x, Purchased April 2020) Problem: Router powers on, wh...
- Apr 26, 2026
This issue was resolved with factory reset which for some reason wasn't going through in my initial few attempts. Also with firmware update my routers pass through speed has increased 7-8x than earlier. Thank you.
KevinLiT
Apr 20, 2026NETGEAR Moderator
Hello rohanzanje ,
Welcome to the NETGEAR Community!
I understand that you have not been able to successfully use TFTP to recover your RBR750. Since the TFTP is responding to ICMP it means that there is a connection. However, there could be something else that prevents this process from being successful.
Please follow the directions listed in the link below for additional details about the TFTP process:
Best,
Kevin
Community Team
