rohanzanje
Apr 18, 2026Aspirant
RBR750 Boot Loop - White Light Flashes Then Goes Dark, TFTP Recovery Failing
RBR750 Boot Loop - White Light Flashes Then Goes Dark, TFTP Recovery Failing Device: Orbi RBR750 (Serial: 6661037RA0169, Firmware was V7.x, Purchased April 2020) Problem: Router powers on, wh...
- Apr 26, 2026
This issue was resolved with factory reset which for some reason wasn't going through in my initial few attempts. Also with firmware update my routers pass through speed has increased 7-8x than earlier. Thank you.
rohanzanje
Apr 26, 2026Aspirant
Apr 27, 2026Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
rohanzanje wrote:This issue was resolved with factory reset which for some reason wasn't going through in my initial few attempts. Also with firmware update my routers pass through speed has increased 7-8x than earlier. Thank you.
