Netgear61
Oct 24, 2026Aspirant
RBR750 Firmware Bug Report: DHCP Table Fails to Rebuild Automatically After Power Outage
Product/Model: NETGEAR Orbi WiFi 6 Router (RBR750) Firmware Version: V7.2.8.8_5.1.24 Description of the Issue: Following any sudden power outage, the RBR750 router fails to properly reini...
Oct 24, 2026Guru - Experienced User
How was the FW updated on the RBR?
Using default DHCP IP address pool range or custom? Try making the pool smaller, i.e. .100 to .200.
Netgear61
Oct 25, 2026Aspirant
Yes, I have done a factory reset since update. This has been an issue before and after the most recent update. The update was done over the air when logged into the main router via web browser. I had to manually perform the update on the satellite router after the main router. They both now show the most up to date firmware. It has been a real cluster. Like I said, I am no tech guru, but it appears there is an issue with Orbi router. Wifi routers should be simple and not this much trouble. I have Comcast Xfinity for internet provider.
