dbrb2
Jul 19, 2025Apprentice
RBR750 Internal server error
Damn. 2 nights ago my RBR750 started showing an error 500 interal server error It still works as an AP, but the satellite will not connect - so half the wifi is down A power cycle had no e...
dbrb2
Jul 20, 2025Apprentice
RBS came up on its own overnight.
RBR seems now to be working - albeit without a web interface
Seems like maybe the Orbi firmware is just a bit fragile! For now it is working though (I realise this same thing happened last December, then....became OK again for unknown reasons!)
- FURRYe38Jul 21, 2025Guru - Experienced User
I'd follow this and factory reset the system and setup from scratch using a wired PC and web browser:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
I had my 850 series online for over 30 days with this version of FW and saw no web UI access issues:
Share your Orbi 350, 750, 850 or 960 series system UpTime | NETGEAR Communities
- dbrb2Jul 21, 2025Apprentice
Because this has happened a few times, I decided to bite the bullet and go for a pair of Cudy WR3000S configured as "dumb" wired AP with openWRT
Maybe not as fancy, but for now doing the job. Fingers crossed!
