Stefan-M034
Jun 28, 2022Aspirant
RBR750 pink light every day
Hi!
I installed a couple days ago the Netgear Orbi RBR750 and when it works, it really works good. The only thing is that the router show every morning when i wake up the pink light. I already reset the router and buy CAT6a cables. Those things don't fixed te problem.
When i reboot the router everything works again. I checked also if i had internet by the provider self and yes that internet works when the Orbi router doesn't work.
What i can do more the fix this?
Thanks in advance!
After trying the suggested changes by ekhalil you might want update FW on the Orbi system at some point:
Stefan-M034 wrote:
Hi FURRYe38,
I have the Firmware version: V4.6.5.14 (the last version). The router is an TP-link Archer XR500v and i connected with the ethernet cable.
- ekhalilMaster
This looks to be cause by a long DHCP lease time set by your internet operator:
Please login to the web interface (orbilogin.com) >> Go to ADVANCED >> ADVANCED Home >> INTERNET PORT >> CONNECTION STATUS. Check there what is stated under "Lease Obtained".
I had this issue some time ago and I could solve it by changing the "WAN DHCP Lease Time" using telnet commands which is now not possible in Orbi. Fortunately I got this fixed by my internet operator.
- Stefan-M034Aspirant
Thanks!
The status under 'Lease Obtained' is 1 days, 0 Hours, 0 Minutes. For sure I can call the provider. What they need to change exactly with the 'WAN DHCP Lease Time'?
- ekhalilMaster
For me it's 0 Days, 1 Hour, 0 Minutes.
It will be great if the provider can reduce this lease time as much as possible. 1 day is quite long lease time, I guess that's why you have the issue every morning!
Stefan-M034 wrote:
Hi!
Thanks in advance!
Hi FURRYe38,
Stefan-M034 wrote:
Hi FURRYe38,
