Mikems's avatar
Mikems
RBR750 slow
I bought an RBR750 a few months ago and checked my speed from ORBI speed test.  It shows 575 which is good since I have around 500.  Then I ran several tests from the internet and they show under 200.  Why is this so slow?  What can I do?  I purchased from Costco so I could return it?
  • CrimpOn's avatar
    CrimpOn
    Please explain how you ran tests "from the internet".  What device? What test?
    In general, devices connected to the router over WiFi cannot achieve the same rate of speed as devices connected with Ethernet cable.
    • Mikems's avatar
      Mikems
      I did run this with my phone connected to the wifi (orbi).
      • Mikems's avatar
        Mikems
        I used several different internet speeds tests and all tested about the same.  I realize the wifi is going to be a little slow but it is more than 1/2 of the speed I am suppose to get.
  • FURRYe38's avatar
    What devices do you have connected?
    Be sure to speed test with a wired PC connected to the RBR.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
