Justini's avatar
Justini
Guide
Sep 11, 2022
RBR750 (V4.6.9.11_2.3.5) vs Telenor IPTV
Ever since most recent firmware, my Telenor IPTV cuts out for a couple of seconds, every 10 minutes.
Any known workaround?
Anyone else in Norway experience the same?
IGMP proxy is disabled.
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • Justini's avatar
      Justini
      Guide
      Orbi router is not connected to any ISP-provided hardware. Connected directly to Ethernet cable which goes to media converter then fibre.
      I have not tried a factory reset after the latest firmware, so will try that.
      Thanks for the suggestions.
      • FURRYe38's avatar
        What is the brand and model of the media converter? I would power OFF this converter and the Fiber box as well for 1 minute then back ON. Walk thru the setup wizard after you reset the RBR.
