metalgr9's avatar
metalgr9
RBR750 Wi-Fi intermittently goes out, wired connection is fine
Currently running the latest firmware per the Orbi app (v7.2.715). The wifi network from my Orbi router will go out for 30 mins to several hours a couple times a week. This started happening a couple months ago after flawless connectivity for almost two years.
I have AT&T fiber, and the gateway shows an internet connection during these outages. The settings on my fiber modem/gateway have not changed since I started using my Orbi , and my Philips Hue bridge, which is connected to my Orbi router via ethernet, works fine during these wifi outages.
Any ideas on what could be the problem? The connection resolves itself most of the time, but I've had to occasionally power cycle the router when I don't feel like waiting.
  • CrimpOn's avatar
    CrimpOn
    Sometimes the Orbi App fails to detect firmware updates.  Could you please verify the actual firmware release number?
    The support web site shows the most recent firmware to be v7.2.7.15.
    How often does this happen?
    • More than once every day?
    • Every day or so?
    • metalgr9's avatar
      metalgr9
      Per the app, I have v7.2.7.15. This happens a couple times a week.
      • FURRYe38's avatar
