Mataluir's avatar
Mataluir
RBR750 wifi 6 issues
RBR750:
None of my televisions, fire sticks, or Roki support wifi 6 WPA3
Had to go to WPA2
Performance no better than the orbi ac2200 system....
Help
  • plemans's avatar
    The main bottleneck in systems like these are the device you're using and not the router/satellite. If you're device aren't wireless AX you won't see much benefit. where you will see benefit is in concurrent usage. (multiple devices being used at the same time)
    • Mataluir's avatar
      Mataluir
      Okay, so This will still have better performance overall because it will handle a lot more devices. Is this correct?
      Thanks for your prompt attention in responding to my issue.
      Much appreciated.
