kohl
Jul 20, 2025Tutor
RBR850 - add on satellite no longer available, how to add a previously used satellite
I have an RBR850 router with 2 satellites. I needed a third satellite, but am told this is an old model and not available anymore. So I bought a used add-on satellite, and reset it. But I can't se...
kohl
Jul 25, 2025Tutor
I used 192.168.10.250.
Thanks for alerting that I have to update the FW on the second RBR, even though I won't be using it. The IP address doesn't work though. Is there a different set of instructions, to update the FW on the router?
Jul 25, 2025Guru - Experienced User
For all RBRs normal default IP address of 192.168.1.1 will work to get it updated.
Can follow this proceedure here: Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
I use this all the time when manually updating a system. Works well.
- KevinLiTJul 30, 2025NETGEAR Moderator
Hello Khol,
Welcome to the NETGEAR Community!
I understand that you are using FW 192.168.10.250 to connect to your satellite. However, the IP address of 192.168.1.250 is needed to connect to your satellite.
Best,
Kevin
Community Team
- kohlJul 31, 2025Tutor
Thanks all for the suggestions. Unfortunately, when I tried to update the firmware on the second RBR, for some reason the first RBR crashed. So everything is no longer working. I have had to purchase a new system.
appreciate all the help from the community. Much appreciated.
