dglsmcd_USMC
Jul 10, 2020Luminary
RBR850 / RBS850 Firmware Version 3.2.15.32 - Hot Fix-Firmware Update
Addresses security issues-get it here:
https://kb.netgear.com/000062077/RBR850-RBS850-Firmware-Version-3-2-15-32-Hot-Fix
- Kewl. Nat Filter for gamers is fixed in this version. Should be at least.
- Chuck_MMentor
For those that have RBS-50's hard wired to their AX systems -- there is also a corresponding upgrade to the RBS50 firmware found at:
https://www.netgear.com/support/product/RBK50.aspx#download
These potential updates are NOT announced by RBR-850 so you have to get them manually
RBR850, RBS850 and RBR50s took this upgrade very well (albeit manually installed) and are running smooth.
- KMDonlonVirtuosoRunning smoothly here too. Log entries bug is the only issue I am still seeing
- sl0thk1ngAspirant
- sl0thk1ngAspirantYep, I applied it when it first came out just never notice it until today.
