tcappetti
Nov 30, 2020Aspirant
RBR850 Anywhere access not working
Version: 3.2.16.22 Anywhere Access and Speedtest donot work!!
I did the factory reset that solved all problems I had. Thanks
Speed test from the RBRs web page or Orbi app?
Does Ooklas installable speed test app on a PC work?
- tcappettiAspirant
Arris cable modem #SB8200
Yes, full reboot several times.
Speedtest doesnot work from Iphone 12 or the Netgear web page for my RBR850
I have the lastes updates from the web page Ver: 3.2.16.22_1.4.9
I have Spectrum 400Mbps/20Mbps
The Speedtest alone on desktop works fine.
a factory reset and setup from scratch differs from a reboot. Press the reset button for 15 seconds on the RBR and release. Walk thru the setup wizard.
Also FYI:
Something you may want to try with the newer version of FW if you haven't.
