DCP4971
Oct 01, 2026Luminary
RBR850 background Speedtest running?
Hi all,
Been seeing some odd network behaviour relating to my RBK853 that I recently updated to V7.2.8.8_5.1.24 that I'm pretty sure I've tracked back to a background Speedtest that is running every two hours.
I'm running it in AP mode sitting behind a UniFi Cloud Gateway which gives me loads of data about my network. I've been seeing spikes in traffic every couple of hours showing consistently 2.6GB of activity over a period of less than 5 minutes. This activity is directly attributed to the Orbi router but when I dig further, none of the devices connecting to it or the satellites are using anywhere near that amount of data.
This usage is occurring every 2 hours and has been doing so for a number of days - I recently updated the FW to V7.2.8.8_5.1.24 (on 28th Sept).
Based on the pattern, these occur at 50-55mins past the hour, I ran a debug trace on the RBR and looking at the speedtest_result.log I can see a Speedtest running at the time of the debug that I didn't request.
[2026-10-01 16:53:58.854] [info] HTTP request (effective url: https://config.speedtest.net/v1/embed/.........
Looking at the Speedtest results in the web interface a couple of hours later, I can see a more recent speedtest result, which again, I didn't request and the log file in a more recent debug has that later test result. Blocking Speedtest.net at the network level stops it occurring, but, obvs, stops other devices running speed tests.
Am I alone in this? I'm guessing it's perhaps quite niche to be able to see the traffic on the network.
TLDR.. appear to have an automated background Speedtest running every 2 hours. Am I alone?
RBK853
UniFi Cloud Gateway Fiber
ISP modem : Sagemcom device rebranded for my ISP
- DCP4971Luminary
Hmm, ok, rebooted and seems to have stopped. As you were..
- DCP4971Luminary
Posted the other day about this and it seemed to go away after a reboot, but, noticed today that it's run a speedtest in the background again. Coming back to it a couple of hours later and it's run another.
RBR850 background Speedtest running? | NETGEAR Communities
[2026-10-03 13:14:12.377] [info] HTTP request (effective url: https://config.speedtest.net/v1/embed/...
[2026-10-03 15:14:47.105] [info] HTTP request (effective url: https://config.speedtest.net/v1/embed..
Any ideas why? Is this intended behaviour now? Surely for anyone on a metered internet connection this would be a bad thing to not have the option of saying, no, I don't want my router unilaterally running a speedtest that uses 2GB of data without my say-so?
I can probably just block the traffic but I don't think I should have to.
RBK853 all nodes on V7.2.8.8_5.1.24
Since the AX series seems to be EoL, we'll probably not see any changes in this regard. So something you'll just need to block if it's bothering you.
