dprill's avatar
dprill
Tutor
Jul 04, 2020
RBR850 Disconnects happening frequently
Last several weeks I have been getting frequest disconnects on my RBR850 from the internet. I have read through the forum, and tried a whole host of fixes recommended by FURRYe38 and others , but so far none of them have helped. I finally did a fatcory reset today and re-setup the router and the mesh, but still disconnecting frequently. I have the RBR850 router and 2 satellites placed less than 30 feet away from the router.
Current Set up
RBR850 firmware V3.2.15.25_1.3.15
2 RBS850 same firmware level
xFinity Gig service
Arris modem in bridge mode model TG3482G
CTS/RTS set to 2347
2.4GHz channel auto
5 GHz channel 48
20/40MHz coexistence enabled
I don't have options for MIMO or beam froming
Any suggestions? Have the router in debug mode to capture the next disconnect and will upload it when it happens.
Darin
  • Guess you can't upload a zip file, I have the debug and packet captures if needed.
    Darin
  • FURRYe38's avatar
    Is the RBR disconnecting from internet services or is it just wifi devices loosing internet or connection from the RBR or do both wired and wireless get disconnected?
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
    Please send any debug logs to NG support.
    • dprill's avatar
      dprill
      Tutor
      The behavior is very weird. The devices never lose wireless connectivity, but they lose access to the Internet. The RBR does not respond to either the Orbi app, local or remote, nor trying to connect via 192.168.1.1 locally. After several minutes, RBR becomes responsive again. When I check the "logs" (these are the fairly useless general logs) they show no disconnection of the RBR, so it doesn't look like the RBR rebooted or anything, it just became totally unresponsive to outside queries.
      Router and satellite distance is less then 30 feet, one is one floor above so distance is 10-12' and other is in my office, about 20 feet away. Both show strong connectivity to the router.
      I don't have many 2.4Ghz devices, but I will manually set a channel, 5Ghz is already set to channel 48. 2 Wifi neighbors near, signal strengths are low and are both 2.4Ghz.
      How do I send the log to NG support? Is there someplace to open a case that I am missing?
      Thanks for the help and suggestions!
      Darin
      • FURRYe38's avatar
        "Router and satellite distance is less then 30 feet, one is one floor above so distance is 10-12' and other is in my office, about 20 feet away. Both show strong connectivity to the router."
        Lets try moving the RBS out farther from the RBR. 12 and 20 feet to way too close. 30 feet is starting distance minimum.
        One thing you can try and do is turn OFF the RBS and connect everything to the RBR and see if the RBR still fails. If so, this maybe a problem between the RBR and ISP modem.
        Does the front LED on the RBR show any inidications when this happens?
        Have you done a full factory reset on the RBR since the last FW update and setup from scratch?
  • I'm having the same problem with my RBR50v2 w/ Xfinity Gigabit service.
    I was using a Netgear CM500 modem with no trouble, but a few days ago I replaced that modem with an Arris SB8200.
    I get amazing speeds, but since swapping out the modems, I get frequent disconnects from the WiFi network. Maybe ten or twenty seconds when it looks as though the network has disappeared. Then devices reconnect.
    • FURRYe38's avatar
      Please post over in the Orbi AC forum for your model orbi:
      https://community.netgear.com/t5/Orbi/bd-p/Orbi
      Thank you.
