cjf191
Oct 24, 2025Aspirant
RBR850 loses management access after power outage
After a power outage my RBR850 loses the management access. The Internet still works - all devices are connected and working and I can remotely access household published services from the Internet. ...
Oct 25, 2025Guru - Experienced User
Whenever I read that there's a gateway in bridge mode behind another router and there's issues accessing the GUI, it makes me question the gateway. Try powering off the gateway, reboot the netgear, and then see if you can access it when connected to it. I understand you won't have internet but its to check if it accessible without the gateway connected "in bridge mode"
cjf191
Oct 25, 2025Aspirant
Thanks. This makes no difference. Given the router isn’t publishing a http port I can’t access it through the web browser.
- FURRYe38Oct 26, 2025Guru - Experienced User
What FW is loaded on the RBR?
Is IPv6 enabled on the RBR?
Using ISP DNS addresses or custom DNS addresses?
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.- cjf191Oct 27, 2025Aspirant
What FW is loaded on the RBR? none
Is IPv6 enabled on the RBR? no
Using ISP DNS addresses or custom DNS addresses? ISP
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too? Archer VR1600v
- FURRYe38Oct 27, 2025Guru - Experienced User
What FirmWare version is loaded on the RBR?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.Static IP Address Configuration for AP Mode | NETGEAR Communities
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
