cjf191
Oct 24, 2025Aspirant
RBR850 loses management access after power outage
After a power outage my RBR850 loses the management access. The Internet still works - all devices are connected and working and I can remotely access household published services from the Internet. ...
cjf191
Oct 25, 2025Aspirant
Thanks. This makes no difference. Given the router isn’t publishing a http port I can’t access it through the web browser.
Oct 26, 2025Guru - Experienced User
What FW is loaded on the RBR?
Is IPv6 enabled on the RBR?
Using ISP DNS addresses or custom DNS addresses?
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- cjf191Oct 27, 2025Aspirant
What FW is loaded on the RBR? none
Is IPv6 enabled on the RBR? no
Using ISP DNS addresses or custom DNS addresses? ISP
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too? Archer VR1600v
- FURRYe38Oct 27, 2025Guru - Experienced User
What FirmWare version is loaded on the RBR?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.Static IP Address Configuration for AP Mode | NETGEAR Communities
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...- cjf191Nov 02, 2025Aspirant
Firmware is the latest and as per my initial post, the ISP modem is already in bridge mode.
I have restored the saved config and all is back to normal. I’m keeping it away from the Netgear Anywhere Access for now to see if that had something to do with the problem.
- KevinLiTOct 27, 2025NETGEAR Moderator
Hello cjf191,
Welcome to the NETGEAR Community!
I understand that you are having issues accessing the admin portal for your RBR850.
These issues are generally caused by incompatibility within the web browser due to changes done within the browser.
Please try using a different browser to access your admin portal. Other users have been successful with using Mozilla Firefox or Safari.
Best,
Kevin
NETGEAR Team
Thanks but the same browser has been working just fine, and still is. When the problem occurs, all browsers see the same issue.
