cjf191
Oct 25, 2025Aspirant
RBR850 loses management access after power outage
After a power outage my RBR850 loses the management access. The Internet still works - all devices are connected and working and I can remotely access household published services from the Internet. ...
cjf191
Oct 27, 2025Aspirant
What FW is loaded on the RBR? none
Is IPv6 enabled on the RBR? no
Using ISP DNS addresses or custom DNS addresses? ISP
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too? Archer VR1600v
Oct 27, 2025Guru - Experienced User
What FirmWare version is loaded on the RBR?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communities
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
