NorthLondon892's avatar
Sep 21, 2021
RBR850 Out Of Sync after upgrade to Firmware 4.6.3.16
Hey everyone.
Could someone help me please?
I did an update to my Orbi RBR850 router to the latest firmware V4.6.3.16_2.0.51
Since doing this, the satellite in the bedroom is coming up with an "Out of sync" message on the main router page.
I have tried a re-sync but this has not worked.
When I re-boot the main router, it connects and says "Good" for about 5 minutes and then goes back to "Out of sync"
It is also reporting that no devices are connected to it which is not true as I have a full WI-FI signal when I am close to it and getting nearly 1gb speeds.
I have also done a factory re-set which has made no difference.
The other satellite in the office is wired and is reporting no issues at all.
Is this is firmware problem? Are support aware of it and is anyone else having similar issues?
Thank you.
  • FURRYe38's avatar
    What Firmware version is currently loaded on the RBS? Be sure the RBS FW is updated to same version as RBR.
    Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
