ottopaulsen
Nov 02, 2021Tutor
RBR850 still losing internet connection several times a week
All info on previously closed case.
I am still loosing internet connection several times every week.
The thing is that it ALWAYS helps to reboot the router, or even logging in and running Internet setup test gets the connection back up.
So WHY cannot the damn router try reconnecting when the connection has been down for a while?
Today I thought I should check the logs before I restarted, but what did I find there? Absolutely nothing except from what DHCP connections have been made the last 5 minutes. This is totally useless.
I am extremely disappointed after buying the most expensive mesh network I could find, and it looses connections so often. My previous router NEVER lost connection, so don't blame the line.
Is there ANY way to find out what the real problem is?
You may need to factory reset the system and power the system OFF as well.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150287/highlight/true#M21560
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150391/highlight/true#M21575
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150417/highlight/true#M21579Ok, thanks. Guess I have to try this.
I have 32 devices with fixed IP, based on mac address. Is there a way to export and import them, so I don't have to enter one by one through that tedious interface?
Otto
Can try loading the config file and see, if problem continues, i'd try reset and do a test with out loading the backup from file.
Otto
