Mkstretch
Aug 02, 2025Aspirant
RBR850 Unable to join network
I have the rbr850 and 2 rbs850 satellites. I am running the latest firmware. This is a new setup. My devices every few days will disconnect from the Orbi router and when I try to reconnect it says “unable to join network” I then have to reboot the Orbi router to reconnect. It only happens with my Orbi router. Not my satellites. They seem to work fine. Anyone have any idea what could be the issue.
what modem/gateway is the router connected to?
- MkstretchAspirant
My Orbi is plugged into an unmanaged switch coming from a moca adapter. My router is a fios gateway
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
