unscathed
May 17, 2022Aspirant
RBR850 Wifi Drops - Hardwire fine.
I have the Orbii RBR850 system with the Router and 2 satellites and I have been having intermittent problems with WIFI drop outs for a few months now. I use ATT Fiber 1Gup/1Gdown. Current Firmware is 4.6.8.2
I have factory reset my Orbii router 3x so far using both "Router" mode and "AP Mode" and still end up with WIFI drops.
My current connection is wire backhaul to both satellites. The devices that are physically connected via Cat5 have absolutely no problems. This issue only impacts devices connecting via wifi. I have 40+ devices that use wifi from cameras to light switches/smart devices and a couple laptops.
Not sure what else to do here. I have used Orbi since it was originally released, after giving up on Linksys at the time.
Does the front LED turn on WHITE or PINK when this happens?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡CAT5 isn't recommended as its only rated for 100Mpbs. CAT6 is recommended and support 1000mpbs rates.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Armor, Traffic Meter and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings- unscathedAspirant
Sorry.. should of been specific.. Cat5e
Category 5e-1 Gigabit/sec-100 meters (328 feet)
Category 6- 3 Gigabit/sec-100 meters (328 feet)
Home is 3300 Sqft.
I will check the other things you mentioned. - unscathedAspirant
2800 Square foot..
Gateway is a PACE 5268AC
Orbi Router is in AP Mode (most functionality is off) and still had this issue in router mode.
Firmware is V4.6.8.25G on Auto and I have tried 48
2.4G I have done 1,6,11
There are other networks nearby, but mine is the most powerful in the hood.
What mode is the modem working in? Router or Bridge mode? This already has a built in router and wifi.
