Rhyft's avatar
Rhyft
(RBR850/RBS850) - Wifi constantly dropping from all devices
Any update to this? I've had the exact same issue you described (regularly experiencing all devices dropping wifi connection from satellite but devices connected to the satellite via hardwire maintain their connection). Netgear replaced the first satellite thinking it was a hardware issue, but I'm having the exact same issue with the replacement.
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    • Rhyft's avatar
      Rhyft
      Firmware: V4.6.8.5 on both (manually updated, downloaded the RBR and RBS latest versions from Netgear support site). Issue was present before and after update.
      Modem: Moto MB8600
      Home size: 3800 sq ft
      Distance: >30 ft but connected via hardwire. Connection = Modem > RBR > NG GS116NA unmanaged switch > RBS
      Channels: Auto for 2.4, tried all available channels for 5 GHz but no change has resulted in a fix.
      Neighbors: No neighbors within ~400 ft.
      • FURRYe38's avatar
        Set manual channel 1 and 40
        Set CTS to 2347
        Turn down the power from 100% to 50% on the RBR.
        What CAT# lan cable is being used between the RBR, Switch and RBS?
