madtownJason
Apr 17, 2022Aspirant
RBRE960 after power outage only 50-55 will re connect
hello
I have RBRE960 with 2 satellites both wired backhal RBKE963 system with the latest firmware V6.0.3.85 all 3 units are on UPS backup
I have 12-15 wired devices 3 tvs, 2 roku's, 3-5 computers, 3 apc UPSs, Philips-hue hub, a smart things hub .....
on my main ssid I have my 2 iphones 2 apple watches 2 ipads and 1 laptop
I also have 70+ IoT wifi devices IE tplink wall switches/power strips,4 LG appliances, 3 wyze,4 amazon Alexa, 8 Globe smart plugs printer, thermostat, 5 nest smoke/co and a few other that i cant think of at the moment
when ever I have a power outage for more than 2 seconds all of my devices that are not on ups backup reboot so to speak ..
only 50-55 devices in total can reconnect to the router ...the wires devices seam to always get an ip but the wifi devices will fight over the remaining space only 30-45 will connect .....after I hit my 50-55 max. the only way to get a new device to join is to delete an existing device and 80% of the time something else pops in before the device I wanted can join
I have rebooted the router the satellites the modem in every way I can think of I have even moved all three next to the modem so I can re boot at the same time
when chatting with support I did a factory default and re installed the same ssid and got most of them back but still had 10-15 devices that I had to reconnect with the manufactures app
anyone else have issues like this ? or have a different idea on fixing it
madtownJason wrote:when ever I have a power outage for more than 2 seconds all of my devices that are not on ups backup reboot so to speak ..
I have a similar number of devices with my AXE system but I haven't had house-wide power outages like you describe. First thing to confirm are your settings... What is your DHCP range (Advanced / Setup / LAN Setup)? Default should have sufficient IP address range, e.g., 2 to 2xx-something.
Do you have any DHCP reserved addresses setup? What other Orbi settings have you changed from the factory defaults? Do you have any network switches in your device topology? I'd also suggest trying to disconnect your wired satellites and run them wirelessly as an experiment, just to rule that out.
- madtownJasonAspirant
DHCP setup is factory 2-254
I was in the process of setting up DHCP reserved addresses I had 10 or so devices but got side tracked and didn't save the settings before the most recent power outage. unfortunately most of them were the wired connections or on UPS so didn't need to get new IP
I really didn't want to set up reserved addresses for everything unless I have too....looking like that is on my new to do list
the only setting I changed are enabling the 2.4 &5 GHz to be on the same SSID and new SSID and passwords
I have 1 cisco unmanaged switch SG11224NA also on ups power
I did take that out of the equation the first outage, along with the 2 satellites
2 different steps ...first was to remove the switch and only use the router ports the second was to only use the router and not the satellites
unfortunately my house is setup poorly for WiFi and has a lot of concrete and metal so placement of the satellites require them to be wired back haul
One other suggestion to try, and see if it improves things for you, is to set CTS/RTS Threshold to 2347 and disable (uncheck) AX mode for 2.4Ghz. I find these settings improve compatibility with older wireless devices. That would not create the DHCP contention as you describe it, but who knows...
- Go to the web admin portal at http://orbilogin.com/
- Click to the Advanced tab, Advanced left menu, Wireless Settings
- Set CTS/RTS Threshold to 2347 for both 2.4hz and 5Ghz networks
- Press Apply
See if that helps. If problems still persist, next try disabling AX mode for the 2.4Ghz band:
- Go to http://orbilogin.com/
- Click to the Advanced tab, Setup left menu, Wireless Setup
- Uncheck "Enable 2.4G" under the top Enable AX section
- Press Apply
How are the RBS connected to the RBR via ethernet, directly to the back of the RBR or is there a LAN switch in between?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using?
madtownJason wrote:
hello
I have a 1940 house that has plaster and fiber walls the stage in between plaster and lath and drywall it is 94 ft wide and 30 ft deep as well as wood and aluminum siding ....that is the way was when i got it
the RBR is in the center of the house and that gives WiFi to most of the left side of house but i have a large fish tank and a few walls that block to the right so that is RBS#1 is on the far side of the house about 35 ft away and that could be switch to wireless back haul but i have the wire
the RBS#2 is 60ish feet away in a shed in my back yard so my wife can use the WiFi and so I can use some WiFi cameras to keep an eye on my back yard
that is connected using a set of TP-Link MC220L | Gigabit SFP to RJ45 Fiber Media Converter tplink and one of the first things I remove when trouble shooting
WiFi coverage is good throughout the house I can have a bank of three switches and one will reconnect and the other 2 will stay blinking or 2 will reconnect and one will stay blinking until I remove/reboot some other device or even 2 smart plugs in the same room as the RBR it seams totally random as to what devices connect and what don't
neighbors near by 5 in the center of my house the only WiFi I get is my SSID on the left of the house I get 3 plus my 2 SSID on the right I get a different 2 as well as my 2 when I go out side I get about 8 plus my 2 depending on the location in my yard
as far as channels auto for the 2.4 and 48 g
So you have these TP Link Fiber Media Converters in between the RBR and RBS?
