markfMK
May 14, 2022Guide
RBRE960 IoT Network Slow
hi, I’ve had the RBRE960 for a few weeks and getting amazing speeds from the main network. However, I’m having problems with the IOT network, both in terms of speed and the fact that it keeps dropping out. - Speeds less that 20mb down on 2.4ghz
Anyone else experience the same and found a solution ?
thanks
Mark
Not sure of the IoT network portion of the system has fast performances as the main wireless networks. The IoT is mostly for IoT items that don't need fast speeds, just to get connected and be used. Most IoT devices don't need lots of speed.
- markfMKGuideAgreed on the speed part. It’s more on its stability compared to the main network
Has a power OFF of the RBR for 1 minute then back ON since last FW update been performed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
