itguy97223
Dec 12, 2022Aspirant
RBRE960 Satellite Connection to Base Station
I have the RBRE960 with two satellites. One of the satellites I decided to use hardware for the backhaul connection. But now when I log into the router I see the hardwired connection as good and another 5G connection as good. The MAC address shows it is part of the wired satellite. The problem I am having is that 5G connection has a different IP than everything else. So things will connect to that IP and then I am not able to manage them. The only way I have seen to get around this is to assign a IP to each device. How do I get rid of that 5G connection?
For a total of two 5G satellite connections?
Since these are private IP addresses, there should be no harm in sharing them.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️Are RBS ethernet or wirelessly connected to the RBR?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What browser are you using?
- itguy97223Aspirant
I have router and two satellites. One satellite is connected to the router via WiFi backhaul. With IP 192.168.25.200 The second satellite I have connected via Ethernet with IP 192.168.25.201. The second one is wired due to location and interference. The odd satellite with Wi-Fi has IP 192.168.1.250. If I change the second satellite to Wi-Fi backhaul it keeps IP 192.168.25.201. And the odd third one is no longer showing in Orbi router connected satellites. Things do not change if I use IE or Chrome to connect to the router.
Can you provide a screen capture if what your seeing. Edit out any MAC addresses before posting.
What is the size of your home? Sq Ft? What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ️So the wired RBS had is seeing the .1.250 address? Is this RBS directly connected to the back of the RBR or is there a LAN switch in between?
What CAT# lan cable are you using between the RBR and RBS?
Is the RBS connected using the 2.5Gb port on the RBS and RBR?
