nwallace's avatar
nwallace
RBRE960 with 2 Satellites disappeared several times yesterday and today
I've had the system working "well" since November of last year. There have been minor issues, like walking around the house and suddenly my phone is stuck on "Obtaining IP Address..." and won't connect to the WiFi for a while, but that's another story.
Yesterday, the system would just disappear. The Satellites (hardwired) would start flashing white and then solid purple. The computer that is hardwired into the router couldn't pull up the router interface. It's like it wasn't there. Pings would timeout most of the time, but sometimes I'd get a Port Unreachable from the local IP interface.
Power cycling the whole system would help, but only for 30 minutes or so. Last night, on a whim, I changed the NTP server to google, and that seemed to help. But the router blipped out again today. It's been up for an hour and a half, but I'm sure it's just a matter of time.
Nothing changed recently, no new devices or settings changes.
Firmware Version V6.3.7.10_3.3.3
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected
    Are the RBS directly connected to the back of the RBR or is there a LAN switch in between? Brand and model please.
    • nwallace's avatar
      nwallace
      Not sure, haven't tested with just the router, will test next time it goes down.
      It's like the route is gone, so yes, both wired and wireless devices don't see it.
      3000
      What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
      They are hardwired, Cat6
      Yes, both RBS and computer connected directly to the back of the RBR
      • FURRYe38's avatar
        3000
        For this size of home, the RBR and just one RBS would be needed. Having two maybe too much and causing problems. Let turn OFF one RBS for now. https://youtu.be/UR0viMLISz4
        What is the distance between the router and satellite(s)? This is important regardless of wireless or wired connection?
        Are the RBS using the 2.5Gb or 1Gb LAN port connection to the RBR?
