cpmassen
Jul 19, 2022Apprentice
RBS 750 Constantly disconnecting
I have this exact same problem (have had it now for several months) and it is so annoying. Only the devices connected to my satellite on the far side of the house and back deck (TV) are affected. It will disconnect at random times all thru the day. Usually only for a few seconds but enough to destroy a zoom meeting or make watching TV difficult. Something needs to be done to fix this. I have completely reset my entire system and nothing is helping at all.
- cpmassenApprentice
My satellite continues to randomly disconnect all throughout the day. Is there a fix for this? It has been going on for months!
Are you still on this version of FW?
There is newer FW available:
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
This is the satellite firmware
Satellite RBS750 Living Room Satellite V4.6.5.14 No New Firmware Available I am using xfinity for my ISP and I have the ORBI CRB 750 with the built in cable modem.
Router CBR750 CBR750 V4.6.5.8 No New Firmware Available 3100 square foot home. And the satellite is 30 feet (maybe a few more) away from the main unit.
