steve37066
Jun 14, 2022Tutor
RBS350 - Continuous resynching
My satellite continues to re-synch itself at irregular intervals.
Firmware is V4.4.0.10.
Router is RBR350 running the same version of firmware and is running in AP mode.
I have tried changing the WiFi channels to see if that helps but unfortunately there isn't any improvement.
Satellite starts flashing white led which then becomes fixed blue for 3 minutes before switching off. Then after a short period its starts the same sequence.
Router and Satellite are only about 15 feet apart.
Any help appreciated
Steve
- KevinLiTNETGEAR Moderator
Hello steve37066,
I understand your RBS350 is constantly syncing and is only 15 feet away from the router. Lowering your transmit power to 50% can resolve this issue. To change your transmit power please follow the instructions below.
From the router login home page navigate to the following:
- "ADVANCED"
- "Wireless Settings"
- "Transmit Power Control"
Best,
Kevin
Community Team
Hi Kevin,
Thanks for replying,
Have reduced transmit power to 50% for both 2.4 and 5GHz channels but the problem persists.
Any other ideas?
Steve
Hello Steve37066,
Thank you for the update!
Please check your PM.
Best,
Community Team
