Rob6805's avatar
Rob6805
Tutor
Nov 20, 2022
RBS350 satellites lose sync with RBR750
Hello all,
I am having issues with my brand new Orbi system.  I have a RBS750 router and two RBS350 satellites.  The satellites will not maintain a good backhaul sync status.  I have tried resetting the router and satellites and they will show a good status for a period of time and then change to out of sync.
A secondary effect of this I believe is that when the satellites go out of sync they no longer use the same wifi channel as the router.  This is causing an issue with me trying to set up some new cameras I have. The cameras have a limited channel range they will accept and since the satellites are out of sync and using a high channel number (157) the cameras will not connect to the satellites.
What would cause the satellites to not maintain a good sync status with the router?
Thank you
  • CrimpOn's avatar
    CrimpOn
    Can you please identify the package product  number that included one 750 router and two 350 satellites?
    • Rob6805's avatar
      Rob6805
      Tutor
      Ah, I didn't know that ch 157 was for the backhaul signal.  Ok then.  That explains some things.  I have a wifi analyzer app and I can see what networks are available.  Some general questions:
      1) Will the satellites show up as a separate network than the router (same SSID)?
      2)  Is it possible that my phone can connect to the backhaul network (ch 157)?  Because sometimes I see my phone connected to that channel.
      3) When the satellites are out of sync are they working at all?
      Thank you,
  • CrimpOn's avatar
    CrimpOn
    Sorry to nit-pick, but the RBK763 appears to be the Costco P. Ackage of one RBR750 and two RBS760,. No RBS350. I am confused.
  • CrimpOn's avatar
    CrimpOn
    Page 133 of the user manual. The satellites use channel 157 for both user WiFi and backhaul. The router uses different channels for each. (48 user, 157 backhaul)
    Still no
    • CrimpOn's avatar
      CrimpOn
      (every time I try to respond on the tablet, it goes crazy and I get too mad to continue fussing with the damn thing.)
      Still no explanation for why the satellites lose sync.
    • Rob6805's avatar
      Rob6805
      Tutor
      That is not good. I thought the satellites mirrored the router. I do not believe the camera supports ch 157. Do you know if this can be changed?
      Thank you,
      • CrimpOn's avatar
        CrimpOn
        The camera supports channel 157:
  • Has this ever been resolved. Have the identical issue with the identical configuration. Noticing now that Model doesn't show in my satellite config pages. Also can't log into the satellites via IP. Get to login page but will not let me log in using same credentials as my Router.
    • Rob6805's avatar
      Rob6805
      Tutor
      Hello.
      No, it has not been resolved. My cameras will only connect to the Orbi router and not the satellites. And the satellites will not stay in sync with the router. I am currently investigating alternate wifi system and will eventually scrap the Orbi. It's not all it's cracked up to be .
      • Hammerlee's avatar
        Hammerlee
        Star
        That is the impression I am getting too after dealing with the Gear Head staff. Going to try new HW since I was still under warranty...but don't have high hopes.
