LaniO's avatar
LaniO
Follower
Jul 01, 2025
RBS750 does not want to work
Hello, hope this make sense cause my brain is fried. I have an Orbi RBR750 with 2 RBS750 satellites that works with no issue. I bought another RBS750 from eBay since I saw there was some issues with adding others. I reset the eBay rbs and have been trying to add it to my current system without luck. I plugged it into my RBR via Ethernet and it doesn’t want to show as a satellite but when I look on the list it it shows that it is connected to the system and gives it an IP. So I though ok here we go I can get in and update the firmware to be the same as my system and then that will work… nope it ask for username and password which I put in (sticker on bottom as it was factory reset) but no go. Even tried to use the RBR username and pw not also not working. Any advise?
