MajDroid83
Oct 09, 2025Aspirant
RBS750 Oreedoo - Unable to Update Firmware
I am writing to request urgent assistance with updating the firmware on 2 Netgear satellite units (Model: RBS750). I acquired these satellites during my stay in Qatar and while subscribed to Ooredoo....
MajDroid83
Yes I have an RBR (RBR750 to be specific)
Oct 09, 2025Guru - Experienced User
If the RBR is on same v4 version of FW, and the RBS are connected, then manually update the system. Update the RBS first using there web pages with web browser, then update the RBR lastly:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
You might try FW v.21 first
MajDroid83 wrote:Yes I have an RBR (RBR750 to be specific)
- MajDroid83Oct 12, 2025Aspirant
Tried this manual process via admin console and it doesn't work, it's clearly that the firmware is locked and doesn't allow for this. What i'm looking for is to brute force it and upgrade it to the latest official firmware provided by Netgear and not the one provided out of the box
- FURRYe38Oct 12, 2025Guru - Experienced User
Is this system provided to you by an ISP or this Ooredoo Mfr? If so, then you'll need to contact them and ask for additional help and information. Sometimes ISPs or 3rd party companies use NH hardware and develope and load there own firmware code on these units, thus locking out any ability to load NG stock FW on them. Sometimes it can be done or may not be availalbe.
