marwan_zakaria
Jun 01, 2023Aspirant
RBS760 Satellite is not Syncing with CBR750
I had CBR750 with two satellite RBS750 and they all worked. I need more coverage, so I purchased the most recent satellite (and the only one available) a RBS760. The problems started.
I updated the firmware to the absolute latest. The new satellite RBS760 does not sync the SSID and always defaults to its SSID. I have tried rebooting, updating FW and finally re-set and start from scratch. Nothing worked.
I need help.
I have V4.6.14.4 on the CBR750, and V4.6.14.3 on the RBS750, and V6.3.6.4 on the RBS760 (with message stating update failed. I did try multiple times but the update failed does not go away).
Since the RBS760 is newly purchased, it should be eligible for Netgear's 90 days of "complimentary support". It might be worth contacting Netgear to resolve an apparent conflict:
- The published table of "Compatible Satellites" shows the RBS760 as not compatible with the RBR750 router:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible - The Netgear web site shows the single RBS750 satellite available at $199:
https://www.netgear.com/home/wifi/mesh/listing-filter/orbi/ax-wifi6-1/
Amazon also shows the RBS750 as available for $199
It appears that maybe this satellite will not work with the existing system.
- marwan_zakariaAspirantI did check the table. You are absolutely correct. CBR750 is not compatible with RBS750. I lost $250 now. I had assumed an RBS760 which is a newer model should be compatible with a router just few months old. Bad assumption. Thanks
If you are able to reach Netgear support, it might be worth a call
because......
sometimes the meaning of "compatible" is complicated. For example, satellites may not be 'compatible' with the 960 router because they do not support WiFi6E. Whether they would sync up and simply not broadcast the 6E channel is a mystery.
RBS760 satellites are going for just over $150 on eBay right now. I have purchased on eBay, but never attempted to sell anything.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
I need help.
