dklimas
Dec 15, 2022Apprentice
RBS850 ethernet backhaul connected to switch results in loop warning light on switch
I've been having internet connection issues for some time now. I've done a lot of troubleshooting for various things over the last couple months or so after updating firmware. I have now discovered that the loop warning light on one of my switches is on. I thought maybe it might have been elsewhere but I'm the only one that configures the network. Sure enough it goes out as soon as I disconnect the ethernet cable to the satellite.
I'm thinking at minimum powering the satellite on and off to see if that fixes it. Maybe a reset? I see that there has since been another firmware update so I'll save that for last.
Any ideas why this would happen? I know there used to be a "wired backhaul" check box for my 700 series Orbi. I assume it's gone now because it switches automatically with the 800 series. Does it reset itself with a power cycle?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the Mfr and model# of the ethernet switch in the configuration?
How was the RBS connected to the RBR? Wireless sync first then after that, they should connect ok one at a time via ethernet.
What CAT# cable is being used in between the RBR, switch and RBS?
- dklimasApprentice
Current Firmware V4.6.9.11
Arris S33
All external ethernet Cat7 double shielded except for what was installed in the house when built. Looks to be Cat5e.
Switch Qnap QSW-1108-8T
So you're going S33---->rbr850 wan port----->switch------>satellites?
One thing to try is power off the satellites for a short period of time after the router/switch boots and then boot them up.
I've seen it with mine where it'll establish a wireless backhaul first and then the wired. Maybe if they boot up after the router/switch, the wired backhaul will default to that.
You really didn't give us much info other than you have an 8 series orbi and a switch.
What switch is it?
How do you have everything wired?
It should go modem/gateway into the RBR850's wan port. Then from the RBR850's lan port to switch/satellites.
