atiq020's avatar
atiq020
rbse960 always show POOR BACKHUL status
my rbse960 sattelite are always show poor  status  but its not far from the router rbr960 ? i already upgrade the latest uptodate firmware
  • CrimpOn's avatar
    CrimpOn
    How far is "not that far"?  What sort of building materials are in the path between units?
    • atiq020's avatar
      atiq020
      its new home mostly inside all wood small room and not far from router basically say 30 feet upstairs router and sattlite downstairs
      • CrimpOn's avatar
        CrimpOn
        Thanks.  30 ft. is a "normal" distance.  If the connection is reported as "Poor", there must be something blocking the WiFi signal between the two units.  Could be AC ductwork. Metal appliances. a lot of wooden floor joists.  Sometimes moving the router or satellite around will find a better path.
