Tecknono
Oct 07, 2025Aspirant
Issues with 2 printers (canon and epson)
Hello, for some weeks now, without changing anything in my setup, my 2 printers, from 2 different OEM (canon and epson) have lost their Wifi connexions. I am not able anymore to add them on t...
Tecknono
Everything is working fine with 25 other devices connected (computer, phones, alarms, etc)
firmware : v4.4.2.1_3.10.82
channels : set to automatic for 2,4ghz
all satellites and routes are linked with cables
security : wpa2
And I changed nothing…
Oct 07, 2025Guru - Experienced User
Something to contact the printers Mfr about.
- TecknonoOct 07, 2025Aspirant
Why ???
2 printers from 2 differents manufacturers, losing the connexions at the same time, after a firmware update of the Orbi…
everything worked fine for years before that
- FURRYe38Oct 07, 2025Guru - Experienced User
You said you changed nothing on the system and your other devices are working. Kind of includes a FW update.
Try a factory reset and setup form scratch on the Orbi system with a PC and web browser:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
Check with the printers Mfrs for any FW updates on them as well.
