Nobber1066
Jul 31, 2023Aspirant
Re Orbi 960 Black 2.4ghz re 5ghz separate or Shared SSID
Hello
is it better to have one SSID with 2.4 and 5 or should I split out the 2.4 and put it on a different SSID
Thank you
Nobber
What the IoT network is for.
The main WLAN on the Orbi can't be separated. There is the IoT network for each frequency however if you need separate SSIDs.
