MdSazzad's avatar
MdSazzad
Follower
Apr 12, 2024
Re: ORBI Change satellite password
I have an Orbi satelite rbs 750. It's connected to a main router. Now the issue is I cannot log into the satellite and change it's password. We're using the default SSID and wifi password that are written under the bottom side of the satellite. If it's meant to be use router's password why isn’t it using it? We can access the internet but what bothering us is that we can't change the password. I've tried everything like orbilogin.com, orbilogin.net, http://192.168.1.1 and http://10.0.0.1 but nothing seems to be working.
  • CrimpOn's avatar
    CrimpOn
    Thank you for providing the screen shot. This helps a lot.
    Netgear Orbi systems have three different sets of credentials:
    • The WiFi system has an SSID and password that are printed on the bottom of the case, which can be changed by the user during setup (Many users change the WiFi to exactly the same as their previous WiFi system so that all devices will connect automatically. Saves effort.)
    • The Orbi web interface credentials, which are "admin" (which cannot be changed) and "password", which the user is almost forced to change during the initial setup.
    • The Orbi 'app' credentials, which are the Netgear user ID and password used to access the Community Forum.
    The Orbi router and satellite web pages are aessed using the web interface credentials.
  • FURRYe38's avatar
    All Orbi RBS get there log in credentials from the RBR during the wireless sync process. You can not change the RBS credentials. RBS use what ever you set for the RBR.
    Be sure all RBS and RBR firmware is at same level across all units.
