choefler's avatar
choefler
Apprentice
Aug 19, 2024
Re: Possible Fix for iPhone Dropping WiFi
i tried this but the problem is still there..
    • FURRYe38's avatar
      Since your in the EU region, you might try v6 FW since v.21 wasn't supported in the EU region. If you do, RBS first, then RBR lastly, then factory reset and setup from scratch.
      choefler wrote:
      Europa
      v7.2.6.31
      all over Ethernet connected
      is all off
