Barry1m
May 05, 2021Initiate
Turn off SSID broadcast - CBR750/RBS750
How do I turn off SSID broadcast on the CBR750/RBS750? There does not seem to be an entry on any of the (Basic or Advanced) wireless menus.
Speed_54
Jul 10, 2021Initiate
What a BS answer! Let the customer decide if they want to hide it or not.. what concern is it to you if you believe it’s really secure or not. Security by obscurity still works as first line of defense!
Ragar99
Jul 12, 2021Luminary
Protip: Research product features BEFORE you buy!
- CrimpOnJul 12, 2021Guru - Experienced User
Ragar99 wrote:
Protip: Research product features BEFORE you buy!Good advice, but better advice is to purchase with a generous return policy. The original Orbi product has allowed disabling SSID since 2016 ( and still does in v2.7.3.22). One might infer that newer Orbi models wold inherit the same code base. I was totally surprised that Netgear dropped telnet access in this new version. I am not looking forward to the search for my next WiFi system. Thankfully, it will be at least 2-3 years before I own any device that suports WiFi 6 or 6E.
- FURRYe38Jul 12, 2021Guru - Experienced User
Hidden SSID was never inlcuded in Orbi AX systems. I asked about it. Crickets back then.
