rj1031's avatar
rj1031
Security camera can't connect to Orbi AX6000
I recently installed an Orbi AX6000 (RBR850). As soon as I installed it, my outdoor (alarm.com) security camera stopped working. I called the security company (Safehaven-ADT dealer) and requested for a technician to check out the issue.
Long story short, the technician failed to connect the camera to the router (RBR850). He moved the camera closer by 6 feet and the camera worked. The old router supplied by Spectrum worked well with the camera but when I installed the Orbi, things went south.
Any suggestions on how to set-up the Orbi so it can communicate with the ouitdoor camera will be highly appreciated.
Firmware V3.2.15.25_1.3.15
  • rj1031's avatar
    rj1031
    Aug 24, 2020
    End result...
    I had to take the Orbi satellite closer to the camera (inside the garage) in able for it to connect. It's strange how Spectrum's router can easily connect from the same position where the main Orbi is located. I feel like I got robbed spending a lot of money and it didn't perform according to its spec/design.
    Neverthess, I appreciate your help!
  • FURRYe38's avatar
    Is this a 2.4Ghz camera or dual band?
    "He moved the camera closer by 6 feet and the camera worked." So it works near the RBR and doesn't connect at a distance?
    Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
    try changing CTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
    • rj1031's avatar
      rj1031
      "What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected."
      The distance is within 30 feet.
      "Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
      try changing CTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings"
      I will try these settings and let you know.
      Thanks for your help!
      • FURRYe38's avatar
        Try moving the RBS out a bit farther as well. 30 feet or more is recommended.
